Datasheet Texas Instruments PCA9548ADGVR — Даташит
СерияPCA9548A
МодельPCA9548ADGVR
8-канальный переключатель I2C со сбросом 24-TVSOP от -40 до 85
PCA9548A Low Voltage 8-Channel I2C Switch With Reset datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 3 фев 2015
Pin24
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаPD548A
Width (мм)4.4
Length (мм)5
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Channel Width8
I2C Address1110 xxx
Package GroupTVSOP
Simultaneously Active Channels1 to 8
Special FeaturesReset Input,5V Tolerant I/O
VCC(Max)5.5 В
VCC(Min)2.3 В
fSCLK(Max)0.4 МГц
tpd max1 нс
  • Evaluation Modules & Boards: TCA9548AEVM
    TCA9548AEVM: I2C 1-to-8 Bidirectional Translating Switch Evaluation Module
  • Programming Fun Lights With TI's TCA6507
    PDF, 109 Кб, Файл опубликован: 30 ноя 2007
  • Choosing the Correct I2C Device for New Designs
    PDF, 87 Кб, Файл опубликован: 7 сен 2016
    The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h
  • Maximum Clock Frequency of I2C Bus Using Repeaters
    PDF, 116 Кб, Файл опубликован: 15 май 2015
    TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters
  • I2C Bus Pull-Up Resistor Calculation
    PDF, 157 Кб, Файл опубликован: 13 фев 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
  • Semiconductors > Interface > I2C > I2C Switches and Multiplexers
На английском языке: Datasheet Texas Instruments PCA9548ADGVR
