Datasheet Texas Instruments LM95245CIMX/NOPB — Даташит
СерияLM95245
МодельLM95245CIMX/NOPB
В±2В°C Remote and Local Temperature Sensor with TruTherm Technology and SMBus Interface 8-SOIC
Precision Diode Digital Temp Sensor w/TruTherm BJT Comp Tech for 45nm Process datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 22 мар 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка95245CIM
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
InterfaceI2C,SMBus
Local Sensor Accuracy(Max)2 +/- C
Remote Channel1
Remote Diode Temp Range for Listed Accuracy50 to 105 C
Remote Sensor Accuracy(Max)0.75 +/- C
Remote Sensor CorrectionBeta Compensation,TruTherm
Remote Temp Resolution(Max)13 bits
Special FeaturesOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filtering
Supply Current(Typ)350 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2.7 В
Temp Resolution(Max)11 bits
  • Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
На английском языке: Datasheet Texas Instruments LM95245CIMX/NOPB
