Datasheet Texas Instruments SN74LVT16543DLG4 — Даташит
СерияSN74LVT16543
МодельSN74LVT16543DLG4
16-битные зарегистрированные трансиверы ABT 3,3 В с выходами с 3 состояниями 56-SSOP от -40 до 85
3.3-V ABT 16-Bit Registered Transceivers With 3-State Outputs datasheet
PDF, 825 Кб, Версия: C, Файл опубликован: 1 июл 1995
3.3-V ABT 16-Bit Registered Transceivers With 3-State Outputs 56-SSOP -40 to 85
Контест
SN74LVT16543DLG4
SN74LVT16543DLG4
Pin56
Package TypeDL
Industry STD TermSSOP
Width (мм)7.49
Length (мм)18.41
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
RoHSНе совместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Registered Transceiver
На английском языке: Datasheet Texas Instruments SN74LVT16543DLG4
