Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM337KTPR — Даташит
СерияLM337
МодельLM337KTPR
LMx37 3-Terminal Adjustable Regulators datasheet
PDF, 1.3 Мб, Версия: L, Файл опубликован: 12 янв 2015
Pin2
Package TypeKTP
Industry STD TermPFM
JEDEC CodeR-PSFM-G
МаркировкаL337
Width (мм)6.15
Length (мм)6.04
Thickness (мм)1.91
Pitch (мм)4.57
Max Height (мм)2.03
Accuracy(%)3
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.26 | 1ku
Iout(Max)(A)1.5
Iq(Typ)(mA)1.5
Operating Temperature Range(C)0 to 125
Output OptionsAdjustable Output
Negative Output
Package GroupDDPAK/TO-263
TO-220
TO-252
Package Size: mm2:W x L (PKG)See datasheet (PFM)
See datasheet (TO-220)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)2000
Vin(Max)(V)-3
Vin(Min)(V)-40
Vout(Max)(V)-1.2
Vout(Min)(V)-37
RoHSНе совместим
  • How to pick a linear regulator for noise-sensitive applications
    PDF, 255 Кб, Файл опубликован: 22 янв 2013
  • ANY-OUTв„ў LDO Controlled by I2Cв„ў IO Expander Device (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 20 сен 2012
    TPS74201, TPS74301, TPS74401, TPS7A80xx, TPS7A8101 ANY-OUTв„ў LDO Controlled by I2Cв„ў IO Expander Device
  • AN-178 Applications for an Adjustable IC Power Regulator (Rev. B)
    PDF, 219 Кб, Версия: B, Файл опубликован: 5 май 2013
    This application report provides applications for the Texas Instruments LM117 3-terminal adjustableregulator.
  • AN-42 IC Provides On-Card Regulation for Logic Circuits (Rev. B)
    PDF, 593 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application report provides on-card regulation for logic circuits.
  • High Stability Regulators
    PDF, 104 Кб, Файл опубликован: 3 окт 2002
  • Adjustable 3-Terminal Regulator for Low-Cost Battery Charging Systems
  • High-Efficiency Reg has Low Drop-Out Voltage (Rev. B)
    PDF, 60 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Conventional regulators have a high drop-out voltage that is a function of the total output current.However with just a regulator chip an external transistor and a few passive components this designforms a high output current regulator with a limited input voltage and high efficiency. The circuit presentedhas a drop-out of 0.7V at 5A load current and 1.3V at a current level of as high as
  • A New Production Technique for Trimming Voltage Regulators
    PDF, 105 Кб, Файл опубликован: 3 окт 2002
  • AB-12 Wide Adjustable Range PNP Voltage Regulator (Rev. B)
    PDF, 47 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the PNP voltage regulator.
  • AN-182 Improving Power Supply Reliability with IC Power Regulators (Rev. B)
    PDF, 82 Кб, Версия: B, Файл опубликован: 5 май 2013
    This application report discusses improving power supply reliability with IC power regulators.
  • AN-181 3-Terminal Regulator is Adjustable (Rev. B)
    PDF, 314 Кб, Версия: B, Файл опубликован: 5 май 2013
    Until now all of the 3-terminal power IC voltage regulators have a fixed output voltage. In spite of this limitation their ease of use low cost and full on-chip overload protection have generated wide acceptance. Now with the introduction of the LM117 it is possible to use a single regulator for any output voltage from 1.2 V to 37 V at 1.5A. Selecting close-tolerance outp
  • AN-1061 Power Conversion in Line-Powered Equipment (Rev. B)
    PDF, 406 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note describes line-powered equipment and power conversion techniques or methods tosolve those typical power needs.
  • AN-1028 Maximum Power Enhancement Techniques for Power Packages (Rev. B)
    PDF, 684 Кб, Версия: B, Файл опубликован: 6 май 2013
    The purpose of this application report is to aid the user in maximizing the power handling capability of Texas Instruments power packages by using the SOT-223 as an example.
  • Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
    When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet.
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
На английском языке: Datasheet Texas Instruments LM337KTPR
