Datasheet ТI TAS5111DAD — Даташит
| Серия | TAS5111 |
| Модель | TAS5111DAD |
Мощность цифрового усилителя 32-HTSSOP от 0 до 70
TAS5111: Digital Amplifier Power Stage datasheet
PDF, 325 Кб, Версия: D, Файл опубликован: 24 мар 2004
- 126Watts SMPS For TAS511x ApplicationPDF, 629 Кб, Файл опубликован: 18 мар 2004
- Voltage Spike Measurement Technique and Specification (Rev. A)PDF, 179 Кб, Версия: A, Файл опубликован: 13 ноя 2003
As an extension to the voltage ratings given in the Absolute Maximum Ratings section of the TAS5111, TAS5112, TAS5121, and TAS5122 data sheets, this application note gives a more explicit description of the maximum limit for peak voltage vs. time on the BST and OUT pins. Additionally, a measurement technique and test setup is described and application design guidelines given on how to avoid exceed - Power Supply Recommendations for DVD ReceiversPDF, 153 Кб, Файл опубликован: 4 май 2005
Selecting the optimal power supply for a non feed back digital amplifier can bechallenging. Music is dynamic, so the power consumption is changing dramatically,from almost zero to maximum within a few ms.Designing the power supply so powerful that it can deliver the total amplifier outputpower continuously is too costly and usually unnecessary.Designing the power supply too small gives p - PSRR for Purepath Digital Audio AmplifiersPDF, 159 Кб, Файл опубликован: 15 апр 2005
Серия: TAS5111 (1)
- TAS5111DAD
- Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Digital I2S Input Class-D
