Datasheet Texas Instruments LMP91300YZRT — Даташит
СерияLMP91300
МодельLMP91300YZRT
Индуктивный датчик приближения AFE 20-DSBGA от -40 до 125
LMP91300 Industrial Inductive Proximity Sensor AFE datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 27 мар 2014
Pin20
Package TypeYZR
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY250
CarrierJEDEC TRAY (10+1)
МаркировкаATAA
Width (мм)2.3
Length (мм)2.5
Thickness (мм).675
Pitch (мм).5
Max Height (мм).675
# Input Channels1
Analog Supply (V)40 Min
InterfaceSWIF
Package GroupDSBGA
Sensor Frequency5k to 5M Hz
  • Measuring Rp of an L-C Sensor for Inductive Sensing
    PDF, 205 Кб, Файл опубликован: 1 окт 2015
    When designing an application using TI’s LDC series of inductive sensors, it is necessary to know the L-C sensor’s equivalent parallel resistance RP at the sensor’s resonant frequency. The RP value changes as the target is moved; the minimum RP occurs when the metal target is closest to the sensor. The maximum RP occurs when the target is at the farthest distance. Accordingly, both values should b
  • Semiconductors > Sensing Products > Inductive Sensing > Inductive Switches
На английском языке: Datasheet Texas Instruments LMP91300YZRT
