Datasheet Texas Instruments SN74LVC16646ADGGR — Даташит
СерияSN74LVC16646A
МодельSN74LVC16646ADGGR
16-битный шинный приемопередатчик и регистр с выходами с 3 состояниями 56-TSSOP от -40 до 85
SN74LVC16646A datasheet
PDF, 792 Кб, Версия: B, Файл опубликован: 3 май 2004
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVC16646A
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupTSSOP
Package Size: mm2:W x L56TSSOP: 113 mm2: 8.1 x 14(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)13.5,7.3,7,6.1 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Registered Transceiver
На английском языке: Datasheet Texas Instruments SN74LVC16646ADGGR
