Datasheet Texas Instruments LM20143MH/NOPB — Даташит
СерияLM20143
МодельLM20143MH/NOPB
2,95–5,5 В, 3 А, синхронный понижающий стабилизатор тока с регулируемой частотой 16-HTSSOP от -40 до 125
LM20143/LM20143-Q1 3-A PowerWiseв„ў Adjustable Frequency Synchronous Buck Regulator datasheet
PDF, 1.7 Мб, Версия: H, Файл опубликован: 5 янв 2016
30 предложений от 19 поставщиков
LM20143MH/NOPB
70 ₽
Зенер
Россия и страны ТС
LM20143MH/NOPB
от 182 ₽
LM20143MH/NOPB
316 ₽
Эиком
LM20143MH/NOPB
от 423 ₽
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9292
CarrierTUBETUBE
МаркировкаMH20143
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCurrent Mode
Duty Cycle(Max)85 %
Iout(Max)3 A
Iq(Typ)3.5 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking
Switching Frequency(Max)1500 kHz
Switching Frequency(Min)510 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.95 В
Vout(Max)5 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: LM20143EVAL
    3A, PowerWiseВ®: Adjustable Frequency Synchronous Buck Regulator Evaluation Module
  • AN-2077 LM20k POL Module (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 3 май 2013
    The LM20k is a full-featured synchronous buck switching regulator capable of driving up to 6A of loadcurrent and converting an input voltage between 2.95V and 5.5V down to an output voltage as low as0.8V. Fault protection features include cycle-by-cycle current limit, output power good, and output overvoltageprotection. The dual function soft-start/tracking pin can be used to control the sta
  • AN-1747 3A LM20k Reference Designs (Rev. A)
    PDF, 242 Кб, Версия: A, Файл опубликован: 3 май 2013
    The LM20123, LM20133, and LM20143 are a full-featured family of high performance 3A synchronousbuck converters. These devices are tailored to operate over an input voltage range of 2.95 V to 5.5 V andeach can be optimized to meet many different performance requirements. The LM20123 operates at afixed frequency and only requires 11 components to generate a solution. The LM20143 is similar to
Серия: LM20143 (3)
На английском языке: Datasheet Texas Instruments LM20143MH/NOPB
