Datasheet ТI OPA2704EA/250G4 — Даташит
| Серия | OPA2704 |
| Модель | OPA2704EA/250G4 |
12 В, КМОП, Rail-to-Rail ввод-вывод, операционный усилитель 8-VSSOP от -40 до 85
OPA703, 2703, 4703, 704, 2704, 4704: CMOS, Rail-to-Rail, I/O Op Amp datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 8 фев 2001
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - OPA703, OPA2703, OPA4703, OPA704, OPA2704, OPA4704 EMI Immunity Performance (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 2 ноя 2012
- Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2704 (7)
- OPA2704EA/250 OPA2704EA/250G4 OPA2704PA OPA2704UA OPA2704UA/2K5 OPA2704UA/2K5G4 OPA2704UAG4
