Datasheet Texas Instruments UC2848J — Даташит
СерияUC2848
МодельUC2848J
ШИМ-контроллер в режиме среднего тока 16-CDIP от -40 до 85
Datasheet
TSP
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • U-135 The UC3848 Average Current Mode Controller Squeezes Maximum Performance
    PDF, 267 Кб, Файл опубликован: 5 сен 1999
    This application note describes the UC3848 average current mode PWM controller. The unique features of this controller are discussed, which make primary side average current-mode control practical for isolated converters. The UC3848 employs a current waveform synthesizer that monitors switch current and simulates the inductor-current down-slope, generating a complete current waveform without actua
  • U-140 Average Current Mode Control of Switching Power Supplies
    PDF, 325 Кб, Файл опубликован: 5 сен 1999
    Current-mode control, as usually implemented in switching power supplies, actually senses and controls peak inductor current. This process causes many serious problems, including poor noise immunity, a need for slope compensation, and peak-to-average current errors that the inherently low current-loop gain cannot correct. Average current-mode control eliminates these problems and may be used effec
Серия: UC2848 (1)
  • UC2848J
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC2848J
