Datasheet Texas Instruments SN74HC191N3 — Даташит
Серия | SN74HC191 |
Модель | SN74HC191N3 |
4-битные синхронные двоичные счетчики прямого/обратного хода 16-PDIP от -40 до 85
SN54HC191, SN74HC191 datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 2 окт 2003
![]() 7 предложений от 7 поставщиков IC BINARY COUNTER 4-BIT 16DIP | |||
SN74HC191N3 Texas Instruments | 2.93 ₽ | ||
SN74HC191N3 Texas Instruments | 8.50 ₽ | ||
SN74HC191N3 Texas Instruments | 29 ₽ | ||
SN74HC191N3 Texas Instruments | по запросу |
Pin | 16 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Approx. Price (US$) | 0.14 | 1ku |
Bits(#) | 4 |
F @ Nom Voltage(Max)(Mhz) | 28 |
Function | Counter |
ICC @ Nom Voltage(Max)(mA) | 0.08 |
Тип входа | LVTTL/CMOS |
Operating Temperature Range(C) | -40 to 85 |
Output Drive (IOL/IOH)(Max)(mA) | 5.2/-5.2 |
Тип выхода | CMOS |
Package Group | PDIP |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | HC |
Тип | Binary |
VCC(Max)(V) | 6 |
VCC(Min)(V) | 2 |
Voltage(Nom)(V) | 3.3 5 |
tpd @ Nom Voltage(Max)(ns) | 41 |
RoHS | Не совместим |
- HCMOS Design Considerations (Rev. A)PDF, 207 Кб, Версия: A, Файл опубликован: 9 сен 2002
This document describes a potential problem designers may encounter when using high-speed CMOS (HC) logic devices. There also is a broad range of CMOS-system to non-CMOS-system interfaces that need to be considered. The design engineer inevitably encounters these interfaces. Key considerations for handling these interfaces are also discussed in this book.
Серия: SN74HC191 (9)
- Semiconductors > Logic > Specialty Logic > Counter/Arithmetic/Parity Function
