Datasheet Texas Instruments PCA9546ADG4 — Даташит
| Серия | PCA9546A |
| Модель | PCA9546ADG4 |
4-канальный коммутатор I2C и SMBus с функциями сброса 16-SOIC от -40 до 85
PCA9546A Low Voltage 4-Channel I2C and SMBus Switch with Reset Function datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 28 апр 2016
Купить PCA9546ADG4 на РадиоЛоцман.Цены — от 37 до 117 ₽8 предложений от 8 поставщиков Чип интерфейса, I2C Multiplexer 1Element 4IN 16Pin SOIC Tube | |||
| PCA9546ADG4 Texas Instruments | 37 ₽ | ||
| PCA9546ADG4 Texas Instruments | 83 ₽ | ||
| PCA9546ADG4 Texas Instruments | по запросу | ||
| PCA9546ADG4 | по запросу | ||
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 40 |
| Carrier | TUBE |
| Маркировка | PCA9546A |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Channel Width | 4 |
| I2C Address | 1110 xxx |
| Package Group | SOIC |
| Simultaneously Active Channels | 1 to 4 |
| Special Features | Reset Input,5V Tolerant I/O |
| VCC(Max) | 5.5 В |
| VCC(Min) | 2.3 В |
| fSCLK(Max) | 0.4 МГц |
| tpd max | 1 нс |
- Programming Fun Lights With TI's TCA6507PDF, 109 Кб, Файл опубликован: 30 ноя 2007
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: PCA9546A (19)
- Semiconductors > Interface > I2C > I2C Switches and Multiplexers
