Datasheet Texas Instruments OPA453TA-1 — Даташит
СерияOPA453
МодельOPA453TA-1
Операционные усилители 80 В, 50 мА 7-TO-220 от -40 до 125
OPA452, 453: 80V, 50mA Operational Amplifiers datasheet
PDF, 917 Кб, Версия: C, Файл опубликован: 10 ноя 2003
Pin7
Package TypeKVT
Industry STD TermTO-220
JEDEC CodeR-PZFM-T
Package QTY50
МаркировкаOPA453T
Width (мм)8.34
Length (мм)10.16
Thickness (мм)4.6
Max Height (мм)4.7
Additional FeaturesDecompensated
АрхитектураFET
CMRR(Min)86 дБ
CMRR(Typ)94 дБ
GBW(Typ)7.5 МГц
Input Bias Current(Max)100 pA
Iq per channel(Max)6.5 мА
Iq per channel(Typ)5.5 мА
Количество каналов1
Offset Drift(Typ)5 uV/C
Output Current(Typ)50 мА
Package GroupTO-220
Package Size: mm2:W x LSee datasheet (TO-220) PKG
Rail-to-RailNo
Slew Rate(Typ)23 V/us
Total Supply Voltage(Max)80 +5V=5, +/-5V=10
Total Supply Voltage(Min)20 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
OPA453TA1, OPA453TA 1
На английском языке: Datasheet Texas Instruments OPA453TA-1
