Datasheet Texas Instruments ADC12D1600CCMLS — Даташит
СерияADC12D1600QML-SP
МодельADC12D1600CCMLS
ADC12D1600QML 12-Bit, 3.2/2.0 GSPS RF Sampling ADC datasheet
PDF, 904 Кб, Файл опубликован: 17 дек 2012
Pin376376
Package TypeNAANAA
Industry STD TermCCGACCGA
JEDEC CodeS-CBGA-NS-CBGA-N
Package QTY11
CarrierTUBETUBE
МаркировкаADC12D1600CCMLS
Width (мм)27.9427.94
Length (мм)27.9427.94
Thickness (мм)2.792.79
Pitch (мм)1.271.27
Max Height (мм)3.53.5
# Input Channels2,1
Analog Input BW2400 МГц
АрхитектураFolding Interpolating
DNL(Max)0.5 +/-LSB
DNL(Typ)0.5 +/-LSB
ENOB8.9 Bits
INL(Max)2.5 +/-LSB
INL(Typ)2.5 +/-LSB
Input BufferYes
Input Range0.8 Vp-p
InterfaceParallel LVDS
Рабочий диапазон температурот -55 до 125,25 до 25 C
Package GroupCCGA
Package Size: mm2:W x L376CCGA: 781 mm2: 27.94 x 27.94(CCGA) PKG
Power Consumption(Typ)3880 mW
RatingSpace
Reference ModeInt
Разрешение12 Bits
SFDR61.5 дБ
SINAD55.4 дБ
SNR56.6 дБ
Sample Rate(Max)1600,3200 MSPS
RoHSSee ti.com
  • Evaluation Modules & Boards: ADC12D1600CVAL
    ADC12D1600QML-SP 12-Bit, Dual 1.6- or Single 3.2-GSPS, RF-Sampling ADC Evaluation Module - Aerospace
  • Signal Chain Noise Figure Analysis
    PDF, 615 Кб, Файл опубликован: 29 окт 2014
  • Wide Bandwidth Receiver Implementation by Interleaving Two Giga-Sampling ADCs
    PDF, 621 Кб, Файл опубликован: 7 дек 2015
  • Synchronizing the Giga-Sample ADCs Interfaced with Multiple FPGAs
    PDF, 943 Кб, Файл опубликован: 6 авг 2014
  • AN-2128 ADC1xD1x00 Pin Compatibility (Rev. C)
    PDF, 60 Кб, Версия: C, Файл опубликован: 1 май 2013
    In order to facilitate upgrading applications from a 10-bit Gig ADC to a 12-bit Gig ADC, the ADC10D1x00(ADC10D1500/ADC10D1000) is designed to be pin-compatible with the ADC12D1x00(ADC12D1800/1600/1000). This means that a single board layout may be designed with both resolutionADCs in mind for more cost efficient and time-to-market product development.
  • From Sample Instant to Data Output: Understanding Latency in the GSPS ADC
    PDF, 392 Кб, Файл опубликован: 18 дек 2012
    For many applications which use ultra high-speed ADCs, latency can be a critical performance specification. For example, if the ADC is used in any kind of feedback loop, then the absolute latency is an important factor. For a MIMO system such as a phased array radar, the relative difference and variability in latency becomes important. This application note covers latency in the GSPS ADC products,
  • AN-2132 Synchronizing Multiple GSPS ADCs in a System: The AutoSync Feature (Rev. G)
    PDF, 169 Кб, Версия: G, Файл опубликован: 3 фев 2017
Серия: ADC12D1600QML-SP (2)
  • Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
На английском языке: Datasheet Texas Instruments ADC12D1600CCMLS
