Datasheet Texas Instruments TL062CPW — Даташит
СерияTL062
МодельTL062CPW
Двойной маломощный операционный усилитель общего назначения с входом JFET 8-TSSOP 0–70
TL06xx Low-Power JFET-Input Operational Amplifiers datasheet
PDF, 2.5 Мб, Версия: L, Файл опубликован: 26 май 2015
35 предложений от 17 поставщиков
Зенер
Россия и страны ТС
TL062CPW
от 46 ₽
TL062CPW
972 ₽
TL062CPW*
727GS
TL062CPW
Package TypePW
Industry STD TermTSSOP
Package QTY150
МаркировкаT062
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)70 дБ
CMRR(Typ)86 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)200 pA
Iq per channel(Max)0.25 мА
Iq per channel(Typ)0.2 мА
Количество каналов2
Offset Drift(Typ)10 uV/C
Output Current(Typ)10 мА
Package GroupTSSOP
Package Size: mm2:W x L8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG
Rail-to-RailIn to V+
Slew Rate(Typ)3.5 V/us
Total Supply Voltage(Min)7 +5V=5, +/-5V=10
Vn at 1kHz(Typ)42 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)15 мВ
  • Understanding Operational Amplifier Specifications
    PDF, 273 Кб, Файл опубликован: 13 июл 1998
    Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen
  • Handbook of Operational Amplifier Applications (Rev. B)
    PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
    While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
На английском языке: Datasheet Texas Instruments TL062CPW
