Datasheet Texas Instruments TPS70950DRVT — Даташит
СерияTPS709
МодельTPS70950DRVT
150 мА, 30 В, сверхнизкий Iq стабилизатор с широким входом и низким падением напряжения (LDO) с защитой от обратного тока 6-WSON от -40 до 125
TPS709 150-mA, 30-V, 1-µA IQ Voltage Regulators with Enable datasheet
PDF, 2.1 Мб, Версия: G, Файл опубликован: 4 ноя 2015
Pin6
Package TypeDRV
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
Width (мм)2
Length (мм)2
Thickness (мм)0.75
Pitch (мм)0.65
Max Height (мм)0.8
Точность2 %
Основные особенностиEnable,Reverse Current Protection
Fixed Output Options1.2,1.35,1.5,1.6,1.8,1.9,2.5,2.7,2.8,3,3.3,3.6,3.8,3.9,5,6 В
Iout(Max)0.15 A
Iq(Typ)0.001 мА
Noise190 uVrms
Output Capacitor TypeCeramic
Output OptionsFixed Output
PSRR @ 100KHz26 дБ
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Regulated Outputs1
Thermal Resistance ОёJA73 В°C/W
Vdo(Typ)300 мВ
Vin(Max)30 В
Vin(Min)2.7 В
Vout(Max)6 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: MULTIPKGLDOEVM-823
    Universal Low-Dropout (LDO) Linear Voltage Regulator Evaluation Module
  • Evaluation Modules & Boards: LMG1020EVM-006
    LMG1020 GaN low-side driver + GaN FET LiDAR Evaluation Module
  • Evaluation Modules & Boards: TPS70933EVM-110
    TPS70933 Evaluation Module
  • Linear power for automated industrial systems
    PDF, 1.8 Мб, Файл опубликован: 9 янв 2015
    Designing a robust power management system for industrial automated equipment requires thorough understanding of the surroundings and conditions that affect the functionality. During the past few decades industrial and factory automation systems have become more robust intelligent and connected which has drastically increased the footprint for semiconductor components. This change has created a
На английском языке: Datasheet Texas Instruments TPS70950DRVT
