Datasheet Texas Instruments LM3464MH/NOPB — Даташит
СерияLM3464
МодельLM3464MH/NOPB
Светодиодный драйвер с динамическим контролем высоты и интерфейсами термоконтроля 28-HTSSOP от -40 до 125
LM3464/4A LED Driver w/Dynamic Headroom Control & Thermal Control Interfaces datasheet
PDF, 1.6 Мб, Версия: F, Файл опубликован: 1 май 2013
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY48
МаркировкаLM3464MH
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Dimming MethodAnalog,PWM
Входное напряжениеDC Linear,DC/DC Type
Iout(Max)4 A
Iq(Typ)2.3 мА
Package GroupHTSSOP
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
Power Factor CorrectionN/A Min
Regulated Outputs4
Special FeaturesEnable/Shutdown,Thermal Foldback,Thermal Shutdown
TopologyCurrent Sink,Multi-Channel
ТипConverter,Linear
Vin(Max)80 В
Vin(Min)12 В
Vout(Max)80 В
Vout(Min)0.9 В
Vref0.2 В
  • Evaluation Modules & Boards: LM3464EVAL
    4 Channel LED Driver Evaluation Board
  • Evaluation Modules & Boards: LM3464-120V24W
    LM3464 and LM5021 DHC 25W Reference Design with 4 LED strings
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
  • AN-2102 LM3464 and LM5021 DHC 25W Reference Designs (Rev. A)
    PDF, 8.3 Мб, Версия: A, Файл опубликован: 1 май 2013
    This evaluation board consists of a Texas Instruments LM5021-based 120Vac 24W AC/DC flybackconverter and a LM3464-based dynamic head room control (DHC) four channel LED driver IC. Thisdemonstration platform was developed so that the customers could evaluate the LM3464 with an AC/DCsupply.
Серия: LM3464 (2)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3464MH/NOPB
