Datasheet Texas Instruments MSP432P401RIZXHR — Даташит
СерияMSP432P401R
МодельMSP432P401RIZXHR
32-битный микроконтроллер SimpleLink с низким энергопотреблением ARM Cortex-M4F, прецизионным АЦП, флэш-памятью 256 КБ и ОЗУ 64 КБ 80-NFBGA от -40 до 85
MSP432P401R, MSP432P401M SimpleLinkв„ў Mixed-Signal Microcontrollers datasheet
PDF, 2.7 Мб, Версия: G, Файл опубликован: 26 сен 2017
Pin80
Package TypeZXH
Package QTY2500
МаркировкаP401R
Width (мм)5
Length (мм)5
Thickness (мм).65
ADC Channels24
ADC Resolution14 Bits
ADC Sampling Rate1 MSPS
Active Power80 uA/MHz
CPUARM Cortex-M4F
Comparators16
DMA8
Device TypeMCU
Flash256 KB
Тактовая частота48 МГц
GPIO48,64,84
I2C4
Package GroupNFBGA
RAM64
RX Current (Lowest)N/A мА
Reference TypeInternal & External
SPI8
Security EnablerCryptographic acceleration,Debug security,Device identity,Secure FW and SW update,Software IP protection
TechnologyHost MCUs
Throughput(Max)N/A Mbps
Timers - 16-bit6
Timers - 32-bit2
UART4
Vcc range1.62,3.7 В
Wakeup Time8 us
  • Evaluation Modules & Boards: CC256XCQFN-EM
    CC2564C Dual-Mode BluetoothВ® Controller Evaluation Module
  • Development Kits: CC3120BOOST
    SimpleLinkВ™ Wi-FiВ® CC3120 Wireless Network Processor BoosterPackВ™ Plug-In Module
  • JTAG Emulators/ Analyzers: MSP432-DEBUGGERS
    Debuggers for MSP432
  • Evaluation Modules & Boards: MSP-TS432PZ100
    100-pin Target Development Board for SimpleLinkВ™ MSP432P4x MCUs (microcontroller not included)
  • Evaluation Modules & Boards: BOOSTXL-SENSORS
    Sensors BoosterPack Plug-In Module
  • Development Kits: BOOSTXL-K350QVG-S1
    Kentec QVGA Display BoosterPack
  • Evaluation Modules & Boards: CC3100BOOST
    SimpleLinkВ™ Wi-FiВ® CC3100 wireless network processor BoosterPackВ™ plug-in module
  • Evaluation Modules & Boards: MSP-EXP432P401R
    SimpleLinkВ™ MSP432P401R LaunchPadВ™ Development Kit
  • Evaluation Modules & Boards: BOOST-CC2564MODA
    Dual-mode BluetoothВ® CC2564 module with integrated antenna BoosterPackВ™ plug-in module
  • Development Kits: BOOSTXL-EDUMKII
    Educational BoosterPack MKII
    MSP EnergyTrace Technology
  • Getting Started With EEMBCВ® ULPBenchв„ў on MSP-EXP432P401R
    PDF, 1.2 Мб, Файл опубликован: 19 мар 2015
    This is a getting started guide for obtaining the ULPMark™-CP score using the Embedded Microprocessor Benchmark Consortium (EEMBC) ULPBench™ and EnergyMonitor with the MSP432P401R microcontroller (MCU). This document uses the MSP‑EXP432P401R LaunchPad™ development kit as the target evaluation module (EVM) for performing the benchmark. ULPBench is an EEMBC benchmark that provides an industry-standa
  • XMS432P401x Rev. C Preproduction Advisories (Rev. A)
    PDF, 24 Кб, Версия: A, Файл опубликован: 11 июл 2016
  • Signal Processing With MSP432 Microcontroller and CMSIS-DSP Library
    PDF, 526 Кб, Файл опубликован: 31 май 2016
  • Multi-Frequency Range and Tunable DCO on MSP432P4xx Microcontrollers (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 23 июн 2016
  • Proper Sleep and Interrupt Use on the SimpleLinkв„ў MSP432в„ў ARMВ® CortexВ®-M4 MCUs
    PDF, 28 Кб, Файл опубликован: 7 июн 2017
    This application note helps developers understand the proper way to go to sleep using the Wait For Interrupt (WFI) instruction in an ARMv7-M or ARMv6-M application, particularly when using the SimpleLink MSP432 microcontrollers. If System Control Register (SCR) bits are not set in a particular order and a Data Synchronization Barrier (DSB) is not executed to flush the data memory transfer pipeline
  • Designing an Ultra-Low-Power (ULP) Application With SimpleLink MSP432 MCUs (Rev. A)
    PDF, 487 Кб, Версия: A, Файл опубликован: 7 мар 2017
    With the growing system complexity in ultra-low-power microcontroller (MCU) applications minimizing the overall energy consumption is one of the most difficult problems to solve. Multiple aspects including silicon other onboard hardware components and application software must be considered. There are some obvious generic techniques that can be used to reduce energy consumption such as reducing
  • Debugging DriverLib in ROM on MSP432P4xx
    PDF, 270 Кб, Файл опубликован: 18 мар 2015
    The MSP432P4xx family includes a complete peripheral driver library (DriverLib) fully integrated into the ROM memory. Developers can leverage the ROM DriverLib for multiple benefits including access to highly robust and tested APIs, single-cycle ROM execution speed at lower power consumption, and freeing up memory space for additional application code. Developers can gain access to ROM APIs by add
  • Configuring Security and Bootloader (BSL) on MSP432P4xx Microcontrollers (Rev. D)
    PDF, 55 Кб, Версия: D, Файл опубликован: 14 июл 2017
    With the increasing threats of IP theft and cyberattack, security has changed from a feature to a basic requirement for any embedded application. The MSP432P4xx family of devices offers a number of security measures to meet the new security requirements including JTAG security, IP protection, and encryption-enabled bootloader (BSL) (formerly known as the bootstrap loader). In addition, the MSP432P
  • Leveraging Low-Frequency Power Modes on SimpleLinkв„ў MSP432P4xx Microcontrollers (Rev. B)
    PDF, 86 Кб, Версия: B, Файл опубликован: 7 мар 2017
    Low power consumption is very important in all battery powered embedded applications. But the operating frequency of these embedded applications can be diverse based the needs of the application. Some applications might require operating at higher frequencies, in the order of several megahertz, while some other applications might require operating at lower frequencies, on the order of a few tens o
  • Moving From Evaluation to Production With SimpleLinkв„ў MSP432P401x MCUs (Rev. A)
    PDF, 174 Кб, Версия: A, Файл опубликован: 7 мар 2017
    This application report is intended for SimpleLink MSP432 microcontroller (MCU) developers currently evaluating the prerelease SimpleLink XMS432P401x Revision B and Revision C devices sampled from www.ti.com/product/msp432p401r. With the change to production silicon, TI recommends updating your device to the most recent revision of the MSP432 device.NOTE: The SimpleLink MSP432 SDK can be used wi
  • Software IP Protection on MSP432P4xx Microcontrollers (Rev. B)
    PDF, 1.5 Мб, Версия: B, Файл опубликован: 28 ноя 2016
    Differentiations in embedded software applications enable differentiated products. Companies invest significant money in building differentiated software application. Hence, protecting this investment (application or portions of the application) is extremely important. This application note describes how to protect software intellectual property (IP) running on the Texas Instruments (TI) MSP432P4x
  • Flash Operations on MSP432 MCUs
    PDF, 71 Кб, Файл опубликован: 11 июл 2016
    The flash controller of the MSP432в„ў MCUs is a very powerful and intricate peripheral that has a robust programming model and feature-rich implementation. With a proper software layer, the programmer is able to abstract out the complexities of the flash controller's programming model and keep application code free of any flash controller overhead. Additionally, executing DriverLib from ROM enables
  • Maximizing MSP432P4xx Voltage Regulator Efficiency
    PDF, 1.5 Мб, Файл опубликован: 19 мар 2015
    This application report describes the relationship of the MSP432P4xx DC-DC and LDO, provides guidelines on choosing which is most efficient for your application, and gives board layout considerations for the DC-DC.
  • Low-Power Analog Measurements With SimpleLink MSP432 Microcontollers (Rev. A)
    PDF, 538 Кб, Версия: A, Файл опубликован: 19 окт 2017
    Ultra-low-power analog measurements are a common requirement in applications such as non-contact power measurement and wireless condition monitoring. Many of these systems are battery based and must achieve extended life while still providing continuous coverage. This application note describes how to utilize the low-power features of the analog-to-digital converter (ADC) with up to 16-bit precisi
  • BPSK Modem Implementation With SimpleLinkв„ў MSP432в„ў MCUs (Rev. A)
    PDF, 708 Кб, Версия: A, Файл опубликован: 18 сен 2017
    This application report introduces how to implement a 125-kbps BPSK modem by taking advantage of the CMSIS DSP Library with on-chip timer and 1-Msps precision analog-to-digital converter (ADC) with up to 16-bit precision on the SimpleLink MSP432P401R microcontroller (MCU). The MSP-EXP432P401R LaunchPad development kit is used as the main development platform.
  • MSP432 Debugging Tools: Using Serial Wire Output With CCS Trace Analyzer (Rev. A)
    PDF, 911 Кб, Версия: A, Файл опубликован: 23 фев 2016
    This application note introduces an ARMВ® hardware-based debugging tool, Serial Wire Output (SWO) Trace. The discussion starts with background information on what happens at a hardware level, to explain what the many capabilities are. Then, it focuses on how the tools are implemented in the TI Code Composer Studioв„ў (CCS) integrated development environment (IDE), compared to other IDEs.In CCS, the
  • Leveraging Precision ADC on SimpleLink MSP432 MCUs for Predictive Maintenance (Rev. A)
    PDF, 506 Кб, Версия: A, Файл опубликован: 18 сен 2017
    This application report describes a high-performance method for predictive maintenance of motors by monitoring their frequency response with the SimpleLink MSP432P401R microcontroller using precision ADC with up to 16-bit ENOB and FFT analysis.
  • Migrating to the SimpleLink MSP432 Family (Rev. D)
    PDF, 366 Кб, Версия: D, Файл опубликован: 19 окт 2017
    The 16-bit MSP430 and the 32-bit SimpleLink MSP432 microcontroller (MCU) families complement each other in low-power and performance. The goal of this migration guide is to help developers accurately assess the effort to migrate an existing application from the 16-bit MSP430 to the 32-bit SimpleLink MSP432 Arm platform if they so choose to. Ultimately the migration guide is built to help derive a
  • Semiconductors > Microcontrollers (MCU) > SimpleLink MCUs > SimpleLink MSP432 MCUs
На английском языке: Datasheet Texas Instruments MSP432P401RIZXHR
