Datasheet Texas Instruments TPS7101QP — Даташит
СерияTPS71
МодельTPS7101QP
Стабилизатор напряжения 8-PDIP, 500 мА с низким падением напряжения от -40 до 125
Low-Dropout Voltage Regulators datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 22 янв 2003
40 предложений от 22 поставщиков
Чип стабилизации напряжения, Dual Channel LDO Lowest Dropout (LDO) PMOS Adjustable Voltage Regulator LDO Regulator Pos 1.2V to 9.75V 0.5A 8Pin...
TPS7101QP
от 53 ₽
Элитан
TPS7101QP
453 ₽
Hi-Tech Circuit Group
TPS7101QP
TPS7101QP
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Точность3 %
Основные особенностиEnable,Power Good
Fixed Output Options3.3,4.8,5 В
Iout(Max)0.5 A
Iq(Typ)0.28 мА
Noise89 uVrms
PSRR @ 100KHz3 дБ
Package GroupPDIP
Regulated Outputs1
Thermal Resistance ОёJA106 В°C/W
Vdo(Typ)235 мВ
Vin(Max)10 В
Vin(Min)2.5 В
Vout(Max)9.75 В
Vout(Min)1.2 В
  • TMS320C62x/67x Power Supply Solutions for 1-2 DSPs Using the TL5001A and TPS7133 (Rev. A)
    PDF, 190 Кб, Версия: A, Файл опубликован: 1 июн 1999
    This application report describes a low-cost power solution for Texas Instruments' TMS320C6000 DSP applications using the TL5001PWM controller and the TPS7133 low drop-out voltage regulator. The reference design included in this report uses the TL5001AEVM-122 (SLVP122) evaluation module (EVM) which is available for customer testing and evaluation.
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TPS7101QP
