Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI ADS7827IDRBTG4 — Даташит
СерияADS7827
МодельADS7827IDRBTG4
Datasheet Texas Instruments ADS7827IDRBTG4
5,25–2,7 В, 8 бит, 250 KSPS, синхронный последовательный АЦП 8-SON от -40 до 85
10/8/12-Bit High Speed 2.7V microPower? Sampling Analog-to-Digital Converter datasheet
PDF, 1.1 Мб, Файл опубликован: 27 июн 2003
  • Interfacing the MSOP8EVM to TMS320C6x Processors
    PDF, 219 Кб, Файл опубликован: 2 дек 2003
    The modular MSOP8EVM is an evaluation module for single-channel, low-power, 8 to 16-bit serial analog-to-digital converters. This application note presents a method for interfacing this EVM to the TMS320C6x Series DSKs using a 5-6K Interface Board. The EVM software provides compile options to choose the proper data formatting for the ADS7816, ADS7817, ADS7818, ADS7822, ADS7826, ADS7829, ADS7835, A
  • Interfacing the MSOP8EVM to TMS320C5x Processors
    PDF, 225 Кб, Файл опубликован: 28 апр 2004
    This application note presents a method for interfacing the modular MSOP8 evaluation module (EVM), an EVM for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters, to the TMS320C5x series DSKs using a 5-6K interface board. The software developed provides compile options to choose the proper data formatting for the ADS7816, ADS7817, ADS7818, ADS7822, ADS7826, ADS7827, ADS7829
  • Interfacing the MSOP8EVM to MSP430 Processors
    PDF, 54 Кб, Файл опубликован: 28 июл 2004
    This application note presents a method for interfacing the modular MSOP8EVM - an EVM for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters - to the MSP430 series microcontrollers. The hardware used for this example includes the HPA449 from SoftBaugh, Inc. (www.softbaugh.com), featuring the MSP430F449. The software developed provides compile options to choose the proper d
  • Interfacing the MSOP8EVM to TMS470 Processors
    PDF, 68 Кб, Файл опубликован: 15 мар 2006
    This application report presents a method for interfacing the modular MSOP8EVM, an evaluation module (EVM) for single-channel, low-power, 8- to 16-bit serial analog-to-digital converters to the TMS470 series microcontrollers. The hardware used for this example includes the TMS470 Kickstart Development Kit evaluation kit featuring the 60-MHz TMS470R1B1M and the HPA-MCU Interface Board. The soft
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7827 (4)
На английском языке: Datasheet Texas Instruments ADS7827IDRBTG4
Политика конфиденциальности
