Datasheet Texas Instruments AM26LS33ACNE4 — Даташит
| Серия | AM26LS33A |
| Модель | AM26LS33ACNE4 |
Четверной дифференциальный линейный приемник 16-PDIP от 0 до 70
AM26LS32Ax, AM26LS33Ax Quadruple Differential   Line Receivers datasheet
PDF, 1.4 Мб, Версия: F, Файл опубликован: 19 сен 2016
 Купить AM26LS33ACNE4 на РадиоЛоцман.Цены — от 24 до 98 ₽8 предложений от 7 поставщиков Чип интерфейса, Quad Receiver RS-422/RS-423 16Pin PDIP Tube  | |||
| AM26LS33ACNE4 Texas Instruments  | 25 ₽ | ||
| AM26LS33ACNE4 Texas Instruments  | 32 ₽ | ||
| AM26LS33ACNE4 | по запросу | ||
| AM26LS33ACNE4 Texas Instruments  | по запросу | ||
| Pin | 16 |
| Package Type | N |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Package QTY | 25 |
| Carrier | TUBE |
| Маркировка | AM26LS33ACN |
| Width (мм) | 6.35 |
| Length (мм) | 19.3 |
| Thickness (мм) | 3.9 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| ICC(Max) | 70 мА |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | PDIP |
| Rating | Catalog |
| Supply Voltage(s) | 5 В |
| Бессвинцовая технология (Pb Free) | Да |
- Wave Solder Exposure of SMT PackagesPDF, 206 Кб, Файл опубликован: 9 сен 2008
It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
Серия: AM26LS33A (7)
- AM26LS33ACD AM26LS33ACDG4 AM26LS33ACDR AM26LS33ACDRE4 AM26LS33ACDRG4 AM26LS33ACN AM26LS33ACNE4
- Semiconductors > Interface > RS-485/RS-422
