Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74AS808BDWRG4 — Даташит
СерияSN74AS808B
МодельSN74AS808BDWRG4
Шестнадцатеричный 2 входа И драйверы 20-SOIC от 0 до 70
Hex 2-Input And Drivers datasheet
PDF, 608 Кб, Версия: C, Файл опубликован: 1 янв 1995
Pin20
Package TypeDW
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Approx. Price (US$)2.41 | 1ku
Bits(#)6
F @ Nom Voltage(Max)(Mhz)125
ICC @ Nom Voltage(Max)(mA)0.013
Тип входаTTL
Output Drive (IOL/IOH)(Max)(mA)-2/20
Тип выходаTTL
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)(V)5.5
VCC(Min)(V)4.5
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max)(ns)6
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Logic > Gate > AND Gate
На английском языке: Datasheet Texas Instruments SN74AS808BDWRG4
