Datasheet Texas Instruments 5962-87610012A — Даташит
| Серия | SN54AC10 |
| Модель | 5962-87610012A |
Тройные логические элементы положительного NAND с 3 входами 20-LCCC от -55 до 125
SN54AC10, SN74AC10 datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 23 окт 2003
9 предложений от 9 поставщиков Микросхема Логический чип, NAND Gate 3Element 3IN CMOS 20Pin CLLCC Tube | |||
| 5962-87610012A Texas Instruments | 622 ₽ | ||
| 5962-87610012A Texas Instruments | 1 254 ₽ | ||
| 5962-87610012A Texas Instruments | 1 437 ₽ | ||
| 5962-87610012A Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | FK |
| Industry STD Term | LCCC |
| JEDEC Code | S-CQCC-N |
| Package QTY | 1 |
| Carrier | TUBE |
| Width (мм) | 8.89 |
| Length (мм) | 8.89 |
| Thickness (мм) | 1.83 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.03 |
| Mechanical Data | Скачать |
| Bits | 3 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.02 мА |
| Тип входа | CMOS |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | 24/-24 мА |
| Тип выхода | CMOS |
| Package Group | LCCC |
| Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
| Rating | Military |
| Schmitt Trigger | No |
| Technology Family | AC |
| VCC(Max) | 6 В |
| VCC(Min) | 2 В |
| tpd @ Nom Voltage(Max) | 10.5,8 нс |
| RoHS | See ti.com |
- Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - CMOS Power Consumption and CPD Calculation (Rev. B)PDF, 89 Кб, Версия: B, Файл опубликован: 1 июн 1997
Reduction of power consumption makes a device more reliable. The need for devices that consume a minimum amount of power was a major driving force behind the development of CMOS technologies. As a result CMOS devices are best known for low power consumption. However for minimizing the power requirements of a board or a system simply knowing that CMOS devices may use less power than equivale - Implications of Slow or Floating CMOS Inputs (Rev. D)PDF, 260 Кб, Версия: D, Файл опубликован: 23 июн 2016
- TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
Серия: SN54AC10 (6)
- 5962-87610012A 5962-8761001CA 5962-8761001DA SNJ54AC10FK SNJ54AC10J SNJ54AC10W
- Semiconductors > Space & High Reliability > Logic Products > Gate Products
596287610012A, 5962 87610012A
