Datasheet Texas Instruments DAC714HB — Даташит
СерияDAC714
МодельDAC714HB
16-битный цифро-аналоговый преобразователь с последовательным интерфейсом данных 16-CDIP SB от -40 до 85
16-Bit Digital-to-Analog Converter with Serial Data Interface datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 3 ноя 2005
Pin16
Package TypeJD
Industry STD TermCDIP SB
JEDEC CodeR-CDIP-T
Width (мм)7.37
Length (мм)20.57
Thickness (мм)3.5
Pitch (мм)2.54
Max Height (мм)4.45
Рекомендуемая замена
ReplacementDAC714U
Replacement CodeF
Approx. Price (US$)15.23 | 1ku
АрхитектураR-2R
Code to Code Glitch(Typ)(nV-sec)15
DAC: Channels1
Gain Error(Max)(%FSR)0.2
INL(Max)(+/-LSB)1
InterfaceSPI
Internal Reference Drift(Max)(ppm/degC)N/A
Offset Error(Max)(%)N/A
Operating Temperature Range(C)-40 to 85
Output Range Max.(mA)10
Output Range Min.(mA)-10
Тип выходаBuffered Voltage
Package Size: mm2:W x L (PKG)See datasheet (CDIP SB)
See datasheet (PDIP)
Power Consumption(Typ)(mW)525
Priority1
Reference: TypeInt
Resolution(Bits)16
Sample / Update Rate(MSPS)0.086
Settling Time(Вµs)10
Special FeaturesOn-chip Offset and Gain Calibration
SDO
Zero Code Error(Typ)(mV)N/A
RoHSНе совместим
  • Interfacing The DAC714 To Micro-Controllers Via SPI
    PDF, 53 Кб, Файл опубликован: 27 сен 2000
    The DAC714 is a complete, easy-to-use 16-bit digital to analog converter featuring a voltage output with and a precision reference together with a serial interface.
  • Superposition: The Hidden DAC Linearity Error
    PDF, 106 Кб, Файл опубликован: 2 окт 2000
    A digital-to analog converter (DAC) translates digital signals to analog signals. For example, a 12-bit DAC takes a 12-bit binary number, called an input code, and converts it into one of 4,096 analog output voltages or currents. When the contribution to the output voltage or current of each individual bit is independent of any other, it means that the device exhibits no superposition error or tha
  • Semiconductors > Data Converters > Digital to Analog Converter > Precision DAC (=<10MSPS)
На английском языке: Datasheet Texas Instruments DAC714HB
