Datasheet Texas Instruments TPS65131RGER — Даташит
СерияTPS65131
МодельTPS65131RGER
Преобразователь с разделенной шиной и двумя положительными и отрицательными выходами (тип.
TPS6513x Positive and Negative Output DC-DC Converter datasheet
PDF, 1.8 Мб, Версия: D, Файл опубликован: 26 янв 2016
300 мА) 24-VQFN от -40 до 85
Pin2424
Package TypeRGERGE
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка5131TPS6
Width (мм)44
Length (мм)44
Thickness (мм).88.88
Pitch (мм).5.5
Max Height (мм)11
Iout(Max)0.75 A
Iq(Typ)0.5 мА
Package GroupVQFN
Switching Frequency(Max)1500 kHz
Switching Frequency(Min)1250 kHz
TopologySplit-Rail
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)15 В
Vout(Min)3.2 В
Vout2(Max)-2 В
Vout2(Min)-15 В
  • Evaluation Modules & Boards: TPS65131EVM-063
    TPS65131EVM Evaluation Module
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS65131 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost, Inverting or Split-Rail Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS65131RGER
