Datasheet Texas Instruments ADS6422IRGCT — Даташит
СерияADS6422
МодельADS6422IRGCT
Четырехканальный 12-разрядный аналого-цифровой преобразователь (АЦП) с быстродействием 65 MSPS 64-VQFN от -40 до 85
QUAD CHANNEL, 12-BIT, 105/80 MSPS ADC WITH SERIAL LVDS INTERFACE datasheet
PDF, 2.9 Мб, Версия: B, Файл опубликован: 20 дек 2013
Микросхема Преобразователь AD, Analog to Digital Converter Quad 12Bit 65MSPS ADC with serialized LVDS output Quad ADC Pipelined 65MSPS 12Bit Serial...
ADS6422IRGCT
2 676 ₽
ADS6422IRGCT
3 886 ₽
ADS6422IRGCT
6 041 ₽
ADS6422IRGCT
6 041 ₽
Pin64
Package TypeRGC
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаAZ6422
Width (мм)9
Length (мм)9
Thickness (мм).88
Pitch (мм).5
Max Height (мм)1
# Input Channels4
Analog Input BW500 МГц
АрхитектураPipeline
DNL(Max)1.8 +/-LSB
DNL(Typ)0.4 +/-LSB
ENOB11.5 Bits
INL(Max)2 +/-LSB
INL(Typ)1 +/-LSB
Input BufferNo
Input Range2 Vp-p
InterfaceSerial LVDS
Package GroupVQFN
Package Size: mm2:W x L64VQFN: 81 mm2: 9 x 9(VQFN) PKG
Power Consumption(Typ)1050 mW
Reference ModeExt,Int
Разрешение12 Bits
SFDR88 дБ
SINAD71 дБ
SNR71 дБ
Sample Rate(Max)65 MSPS
  • Evaluation Modules & Boards: ADS6422EVM
    ADS6422 Quad-Channel, 12-Bit, 65-MSPS Analog-to-Digital Converter Evaluation Module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Evaluation Modules & Boards: TSW1405EVM
    Data Capture: Data Converter EVMs With 8 LVDS Lanes up to 1.0Gbps
  • Band-Pass Filter Design Techniques for High-Speed ADCs
    PDF, 733 Кб, Файл опубликован: 27 фев 2012
    Several well-known methods exist for designing passive inductor-capacitor (LC) filters with resistive load terminations. However, when LC filters are used to drive the analog input pins of a high-speed analog-to-digital converter (ADC), special consideration must be given to the ADC input impedance. Not accounting for the ADC input impedance often results in a filter design that does not meet the
  • QFN Layout Guidelines
    PDF, 1.3 Мб, Файл опубликован: 28 июл 2006
    Board layout and stencil information for most Texas Instruments Quad Flat No-Lead (QFN) devices is provided in their data sheets. This document helps printed-circuit board designers understand and better use this information for optimal designs.
  • CDCE62005 as Clock Solution for High-Speed ADCs
    PDF, 805 Кб, Файл опубликован: 4 сен 2008
    TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements
  • Design Considerations for Avoiding Timing Errors during High-Speed ADC, LVDS Dat (Rev. A)
    PDF, 2.0 Мб, Версия: A, Файл опубликован: 22 май 2015
  • Why Use Oversampling when Undersampling Can Do the Job? (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 19 июл 2013
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
Серия: ADS6422 (2)
  • Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
На английском языке: Datasheet Texas Instruments ADS6422IRGCT
