Datasheet Texas Instruments OPA544TG3 — Даташит
| Серия | OPA544 |
| Модель | OPA544TG3 |
Высоковольтный сильноточный операционный усилитель 5-TO-220 от -40 до 85
High-Voltage, High-Current Operational Amplifier datasheet
PDF, 883 Кб, Файл опубликован: 27 сен 2000
Купить OPA544TG3 на РадиоЛоцман.Цены — от 319 до 3 388 ₽18 предложений от 13 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS OPA544TG3 Operational Amplifier, Single, 1 Amplifier, 1.4MHz, 8V/µs, ± 10V to ± 35V, TO-220, 5Pins | |||
| OPA544TG3 Texas Instruments | 513 ₽ | ||
| OPA544TG3 Texas Instruments | 662 ₽ | ||
| OPA544TG3 Texas Instruments | 874 ₽ | ||
| Pin | 5 |
| Package Type | KC |
| Industry STD Term | TO-220 |
| JEDEC Code | R-PSFM-T |
| Package QTY | 49 |
| Carrier | TUBE |
| Маркировка | OPA544T |
| Width (мм) | 8.51 |
| Length (мм) | 10.16 |
| Thickness (мм) | 4.58 |
| Pitch (мм) | 1.7 |
| Max Height (мм) | 4.7 |
| Mechanical Data | Скачать |
| Additional Features | N/A |
| Архитектура | FET |
| CMRR(Min) | 90 дБ |
| CMRR(Typ) | 106 дБ |
| GBW(Typ) | 1.4 МГц |
| Input Bias Current(Max) | 100 pA |
| Iq per channel(Max) | 15 мА |
| Iq per channel(Typ) | 12 мА |
| Количество каналов | 1 |
| Offset Drift(Typ) | 10 uV/C |
| Output Current(Typ) | 4000 мА |
| Package Group | TO-220 |
| Package Size: mm2:W x L | See datasheet (TO-220) PKG |
| Rail-to-Rail | No |
| Rating | Catalog |
| Slew Rate(Typ) | 8 V/us |
| Total Supply Voltage(Max) | 70 +5V=5, +/-5V=10 |
| Total Supply Voltage(Min) | 20 +5V=5, +/-5V=10 |
| Vos (Offset Voltage @ 25C)(Max) | 5 мВ |
- Evaluation Modules & Boards: OPAMPEVM
Universal Operational Amplifier Evaluation Module
- DC MOTOR SPEED CONTROLLER: Control a DC Motor without Tachometer FeedbackPDF, 50 Кб, Файл опубликован: 27 сен 2000
DC motor speed is often regulated with a closed-loop speed controller using tachometer feedback. It is possible, however, to control dc motor speed without tachometer feedback. - MTTF, Failrate, Reliability, and Life TestingPDF, 51 Кб, Файл опубликован: 4 окт 2000
At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr - Power Amplifier Stress and Power Handling LimitationsPDF, 55 Кб, Файл опубликован: 27 сен 2000
To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques. - Building your own Battery SimulatorPDF, 114 Кб, Файл опубликован: 14 окт 2013
Building your own Battery Simulator OPA544, bq2409x, bq2404x, bq2415x, bq2425x, bq2416x
Серия: OPA544 (8)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
