Datasheet Texas Instruments OPA2336E/2K5 — Даташит
Серия | OPA2336 |
Модель | OPA2336E/2K5 |
КМОП-операционные усилители MicroPower с однополярным питанием MicroAmplifier Series 8-VSSOP от -40 до 85
OPA336, 2336, 4336: Single-Supply, microPower CMOS Op Amp microAmplifier Series datasheet
PDF, 1.7 Мб, Версия: C, Файл опубликован: 11 янв 2005
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | B36 |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | CMOS |
CMRR(Min) | 76 дБ |
CMRR(Typ) | 86 дБ |
GBW(Typ) | 0.1 МГц |
Input Bias Current(Max) | 10 pA |
Iq per channel(Max) | 0.032 мА |
Iq per channel(Typ) | 0.02 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 1.5 uV/C |
Output Current(Typ) | 5 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 0.03 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.3 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 40 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.125 мВ |
- Precision Absolute Value CircuitsPDF, 100 Кб, Файл опубликован: 2 окт 2000
You can build a precision absolute value circuit using two op amps and two precision resistors. If you use an op amp and an IC difference amplifier no user supplied precision resistors or resistor adjustments are required. Circuits shown are suitable for precision split supply operation and for single-supply operation. When used with a rail-to-rail op amp the single supply circuit can approach a - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2336 (20)
