Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UC1854BL — Даташит
СерияUC1854B
МодельUC1854BL
Advanced High Power Factor Preregulator datasheet
PDF, 732 Кб, Версия: E, Файл опубликован: 25 авг 2006
Pin20
Package TypeL
Рекомендуемая замена
ReplacementUC1854BJ
Replacement CodeP
Control MethodCCM
Duty Cycle(Max)(%)95
Operating Temperature Range(C)-55 to 125
Package GroupCDIP
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
RatingMilitary
Special Features> 750W Applications
Average Current Mode
Enable
UVLO Thresholds On/Off(V)10.5/10
RoHSНе совместим
  • DN-44 UC3854A and UC3854B Advanced Power Factor Correction Control ICs (Rev. A)
    PDF, 158 Кб, Версия: A, Файл опубликован: 15 ноя 2005
  • AC Requirements for Power Factor Correction Circuits
    PDF, 29 Кб, Файл опубликован: 28 мар 2002
    This technical brief identifies the recommended range of IAC for each of the devices within the UCC3854 family of PFC controllers.
  • DN-66 UC3854A/B and UC3855A/B Provide Power Limiting with Sinusoidal Input (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 6 ноя 2001
  • Accurate PWM Duty Cycle Clamp
    PDF, 58 Кб, Файл опубликован: 25 янв 2002
    Power supply applications using current sense transformers require a duty cycle clamp on the pulse width modulator (PWM) to ensure transformer reset. Not all PWMs come with a duty cycle clamp presenting a problem for the power supply designer. This application note shows how to implement a duty cycle clamp by using a simple delay circuit.
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1854BL
