Datasheet ТI LM3S1F16-IQR80-A2T — Даташит
СерияLM3S1F16
МодельLM3S1F16-IQR80-A2T
Datasheet Texas Instruments LM3S1F16-IQR80-A2T
Микроконтроллер Stellaris LM3S 64-LQFP от -40 до 85
Stellaris LM3S1F16 Microcontroller Data Sheet datasheet
PDF, 4.7 Мб, Версия: C, Файл опубликован: 3 июл 2014
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
Серия: LM3S1F16 (2)
LM3S1F16IQR80A2T, LM3S1F16 IQR80 A2T
На английском языке: Datasheet Texas Instruments LM3S1F16-IQR80-A2T
Политика конфиденциальности
