Datasheet Texas Instruments MPC506AU/1K — Даташит
СерияMPC506
МодельMPC506AU/1K
16-канальный аналоговый мультиплексор с односторонним входом 28-SOIC
MPC506, MPC507:Single-Ended 16-Chan/Differential 8-Chan CMOS Analog Multiplexers datasheet
PDF, 727 Кб, Версия: A, Файл опубликован: 17 сен 2003
Pin28
Package TypeDW
Package QTY1000
МаркировкаMPC506AU
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
Additional FeaturesDual supply,Powered off protection,Overvoltage Protection,Break-before-make
Configuration16:1
Input/Ouput Voltage(Max)15 В
Input/Ouput Voltage(Min)-15 В
Input/Output Continuous Current(Max)20 мА
Input/Output OFF-state Capacitance(Typ)5 пФ
Количество каналов1
OFF-state leakage current(Max)0.01 мкА
ON-state leakage current(Max)0.01 мкА
Package Size: mm2:W x L28SOIC: 184 mm2: 10.3 x 17.9(SOIC) PKG
Ron(Max)1800 Ohms
Ron(Typ)1300 Ohms
Supply Current(Max)1500 uA
Supply Current(Typ)700 uA
Supply Range15 Max
VIH(Min)4 В
VIL(Max)0.8 В
Vdd(Max)15 В
Vdd(Min)5 В
Vss(Max)-5 В
Vss(Min)-15 В
  • Multiplexer Data Acquisition System
    PDF, 71 Кб, Файл опубликован: 4 окт 2000
    Multiplexers have been used for acquisition of quasi-static signals for a long time. While these signals usually have a low bandwidth of only a few hertz, applications generally require that the multiplexer send each signal as fast as possible to the converter and that the signals be processed quickly. To ensure fast processing, such acquisition systems usually include a sense amplifier behind the
Серия: MPC506 (3)
На английском языке: Datasheet Texas Instruments MPC506AU/1K
