Datasheet Texas Instruments SN74LVC1G17DSF2 — Даташит
СерияSN74LVC1G17
МодельSN74LVC1G17DSF2
Одиночный буфер триггера Шмитта 6-SON от -40 до 125
SN74LVC1G17 Single Schmitt-Trigger Buffer datasheet
PDF, 1.7 Мб, Версия: V, Файл опубликован: 23 апр 2014
Pin6
Package TypeDSF
Industry STD TermX2SON
JEDEC CodeS-PDSO-N
МаркировкаC7
Width (мм)1
Length (мм)1
Thickness (мм).35
Pitch (мм).35
Max Height (мм).4
3-State OutputNo
Approx. Price (US$)0.05 | 1ku
Bits(#)1
F @ Nom Voltage(Max)(Mhz)150
Gate TypeSCHMITT TRIGGER BUFFER
ICC @ Nom Voltage(Max)(mA)0.01
LogicTrue
Operating Temperature Range(C)-40 to 125
-40 to 85
Output Drive (IOL/IOH)(Max)(mA)24/-24
Package GroupSON
Package Size: mm2:W x L (PKG)See datasheet (SON)
Schmitt TriggerYes
Special FeaturesIoff
down translation to Vcc
low power
Schmitt-trigger
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyLVC
VCC(Max)(V)5.5
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
3.3
5
tpd @ Nom Voltage(Max)(ns)11
6.5
5.5
5
RoHSНе совместим
  • Evaluation Modules & Boards: DLPLCR6500EVM
    DLPВ® LightCrafterв„ў 6500 Evaluation Module
  • Evaluation Modules & Boards: DLPLCR9000EVM
    DLPВ® LightCrafterв„ў 9000 Evaluation Module
  • Evaluation Modules & Boards: DLPLCR4500EVM
    DLPВ® LightCrafterв„ў 4500
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G17DSF2
