Datasheet Texas Instruments SN74AS832BDWRG4 — Даташит
СерияSN74AS832B
МодельSN74AS832BDWRG4
Шестнадцатеричные 2-входовые драйверы ИЛИ 20-SOIC от 0 до 70
Hex 2-Input OR Drivers datasheet
PDF, 950 Кб, Версия: C, Файл опубликован: 1 янв 1995
Микросхема Логический чип, OR Gate 6Element 2IN Bipolar 20Pin SOIC T/R
SN74AS832BDWRG4
126 ₽
SN74AS832BDWRG4
194 ₽
SN74AS832BDWRG4
236 ₽
SN74AS832BDWRG4
488 ₽
Pin20
Package TypeDW
Package QTY2000
МаркировкаAS832B
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Bits6
F @ Nom Voltage(Max)35 Mhz
ICC @ Nom Voltage(Max)0.016 мА
Output Drive (IOL/IOH)(Max)15/-24 мА
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)9 нс
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Logic > Gate > OR Gate
На английском языке: Datasheet Texas Instruments SN74AS832BDWRG4
