Datasheet Texas Instruments UC3825Q — Даташит
| Серия | UC3825 |
| Модель | UC3825Q |
Высокоскоростной ШИМ-контроллер 20-PLCC от 0 до 70
High Speed PWM Controller datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 24 фев 2004
Купить UC3825Q на РадиоЛоцман.Цены — от 24 до 577 ₽17 предложений от 17 поставщиков IC REG CTRLR MULT TOP 20PLCC. Buck, Boost, Flyback, Forward Converter, Full-Bridge, Half-Bridge, Push-Pull Regulator Positive Output Step-Up, Step-Down, Step-Up/Step-Down DC-DC... | |||
| UC3825Q-TI Texas Instruments | 193 ₽ | ||
| UC3825Q Texas Instruments | 252 ₽ | ||
| UC3825Q-TI Texas Instruments | 528 ₽ | ||
| UC3825Q-TI Texas Instruments | по запросу | ||
| Статус продукта | NRND (Не рекомендуется для новых разработок) |
| Pin | 20 |
| Package Type | FN |
| Industry STD Term | PLCC |
| JEDEC Code | S-PQCC-J |
| Package QTY | 46 |
| Carrier | TUBE |
| Маркировка | UC3825Q |
| Width (мм) | 8.96 |
| Length (мм) | 8.96 |
| Thickness (мм) | 4.06 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 4.57 |
| Mechanical Data | Скачать |
| Control Method | Current,Feedforward,Voltage |
| Duty Cycle(Max) | 85 % |
| Frequency(Max) | 1000 kHz |
| Frequency(Min) | 0.1 kHz |
| Gate Drive(Typ) | 1.5 A |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | PDIP,SOIC |
| Rating | Catalog |
| Special Features | Error Amplifier,Multi-topology,Soft Start,Synchronization Pin |
| Topology | Boost,Flyback,Forward,Half-Bridge,Push-Pull |
| UVLO Thresholds On/Off | 9.2/8.4 В |
| Vin(Max) | 30 В |
| Vin(Min) | 8.4 В |
- U-110 1.5 Mhz Current Mode IC Controlled 50-Watt Power SupplyPDF, 298 Кб, Файл опубликован: 5 сен 1999
The UC3825 family of PWM control ICs is optimized for high-frequency switched-mode power-supply applications. This application note describes the development of a 1.5 MHz current-mode IC-controlled 50W power supply. Push-pull topology is used for this DC-to-DC converter application of +48V input to +5V at 10A output. Increases in switching speed and dynamic performance are made possible by the U - Current Doubler Rectifier Offers Ripple Current CancellationPDF, 116 Кб, Файл опубликован: 21 сен 2004
Серия: UC3825 (8)
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
