Datasheet Texas Instruments TPS73643DBVTG4 — Даташит
СерияTPS736
МодельTPS73643DBVTG4
LDO с одним выходом, 400 мА, регулировка (от 1,2 до 5,5 В), без цоколя, низкий уровень шума, защита от обратного тока 5-SOT-23 от -40 до 125
TPS736xx Cap-Free, NMOS, 400-mA Low-Dropout Regulator with Reverse Current Protection datasheet
PDF, 1.3 Мб, Версия: U, Файл опубликован: 14 авг 2014
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаT54
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Точность1 %
Fixed Output Options1.25,1.5,1.6,1.8,1.9,2.5,3,3.2,3.3,4.3 В
Iout(Max)0.4 A
Iq(Typ)0.4 мА
Noise30 uVrms
Output Capacitor TypeCap Free,Ceramic
PSRR @ 100KHz32 дБ
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Regulated Outputs1
Special FeaturesEnable,Foldback Overcurrent Protection,Reverse Current Protection,Soft Start
Thermal Resistance ОёJA53 В°C/W
Vdo(Typ)75 мВ
Vin(Max)5.5 В
Vin(Min)1.7 В
Vout(Max)5.4 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: TMDXDOCK280049M
    F280049M Experimenter's Kit for C2000 Real-Time Control Development Kits
  • Evaluation Modules & Boards: TPS73601DRBEVM-518
    TPS73601DRBEVM-518 Evaluation Module
  • Evaluation Modules & Boards: TUSB1210EVM
    TUSB1210 DP/DM Line External Component Compensation, Vbus Overvoltage Protection Circuit EVM
  • Evaluation Modules & Boards: TAS5722LEVM
    TAS5722L Digital Input Mono Class-D Audio Amplifier Evaluation Module
  • Evaluation Modules & Boards: TAS2559EVM
    TAS2559 5.7-W Class-D Audio Amplifier Evaluation Module
  • Evaluation Modules & Boards: TAS2560EVM
    TAS2560 5.6W Class-D Audio Amplifier Evaluation Module
  • Evaluation Modules & Boards: TAS2557EVM
    TAS2557 5.7-W Class-D Audio Amplifier Evaluation Module with Class-H Boost and Speaker Sense
  • Evaluation Modules & Boards: DEM-SOT223LDO
    DEM-SOT223LDO Compatible with Most Positive Output LDOs in SOT223 (DCQ) Package
  • Extending VOUT Below 1.2 V Using an External Reference
    PDF, 217 Кб, Файл опубликован: 3 окт 2005
    This application report explains how to use an external reference voltage to regulate the output voltage range of a linear regulator below its internal reference voltage.
  • Power Solution for the IntelВ® Atomв„ў E6X5C
    PDF, 27 Кб, Файл опубликован: 29 июн 2011
    Power Solution for the IntelВ® Atomв„ў E6x5x
  • Power Solution using LDO's (Rev. A)
    PDF, 125 Кб, Версия: A, Файл опубликован: 25 мар 2010
  • Taming linear-regulator inrush currents
    PDF, 706 Кб, Файл опубликован: 1 май 2009
  • Q2 2009 Issue Analog Applications Journal
    PDF, 1.7 Мб, Файл опубликован: 1 май 2009
  • Recommended Power Solutions for the TMS320x2810/1/2 DSPs
    PDF, 28 Кб, Файл опубликован: 31 янв 2005
    This application report provides a table to assist users in selecting the best power solution for their specific TMS320281x application.
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
На английском языке: Datasheet Texas Instruments TPS73643DBVTG4
