Datasheet Texas Instruments UC2577TDKTTT-ADJG3 — Даташит
| Серия | UC2577-ADJ |
| Модель | UC2577TDKTTT-ADJG3 |
Простой повышающий стабилизатор напряжения 5-DDPAK/TO-263 от -40 до 125 В.
UC2577-ADJ: Simple Step-Up Voltage Regulators datasheet
PDF, 366 Кб, Версия: A, Файл опубликован: 16 май 2003
Купить UC2577TDKTTT-ADJG3 на РадиоЛоцман.Цены — от 739 до 1 405 ₽13 предложений от 13 поставщиков IC REG MULT CONFG ADJ 3A TO263. Boost, Flyback, Forward Converter Switching Regulator IC Positive Adjustable 5V 1 Output 3A (Switch)... | |||
| UC2577TDKTTT-ADJG3 Texas Instruments | 739 ₽ | ||
| UC2577TDKTTT-ADJG3 Texas Instruments | 1 405 ₽ | ||
| UC2577TDKTTT-ADJG3 Texas Instruments | по запросу | ||
| Pin | 5 |
| Package Type | KTT |
| Industry STD Term | TO-263 |
| JEDEC Code | R-PSFM-G |
| Package QTY | 50 |
| Carrier | SMALL T&R |
| Маркировка | UC2577TD-ADJ |
| Width (мм) | 8.42 |
| Length (мм) | 10.16 |
| Thickness (мм) | 4.58 |
| Pitch (мм) | 1.7 |
| Max Height (мм) | 4.83 |
| Mechanical Data | Скачать |
| Duty Cycle(Max) | 100 % |
| Iq(Typ) | 45 мА |
| Package Group | DDPAK/TO-263 |
| Rating | Catalog |
| Regulated Outputs | 1 |
| Special Features | N/A |
| Switch Current Limit(Min) | 3 A |
| Switch Current Limit(Typ) | 4.3 A |
| Switching Frequency(Max) | 52 kHz |
| Switching Frequency(Min) | 52 kHz |
| Тип | Converter |
| Vin(Max) | 40 В |
| Vin(Min) | 3 В |
| Vout(Max) | 60 В |
| Vout(Min) | 5 В |
- Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed. - DN-49 UC2577 Controls SEPIC Converter for Automotive ApplicationsPDF, 61 Кб, Файл опубликован: 5 сен 1999
The Single-Ended Primary Inductance Converter (SEPIC) can convert an input voltage to an output voltage that is higher, lower, or equal to the input. Conversion is performed without the use of expensive transformers, making the SEPIC a good choice for low-cost, non-isolated applications. The UC2577 provides the switch and control to take advantage of this topology with a minimum of additional part
Серия: UC2577-ADJ (4)
- UC2577T-ADJ UC2577TD-ADJ UC2577TDKTTT-ADJ UC2577TDKTTT-ADJG3
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
UC2577TDKTTTADJG3, UC2577TDKTTT ADJG3
