Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TS3A24157DGSRG4 — Даташит
СерияTS3A24157
МодельTS3A24157DGSRG4
Аналоговый переключатель с двойным SPDT, 0,65 Ом, двухканальный мультиплексор/демультиплексор 2:1, 10-VSSOP от -40 до 85
TS3A24157 0.65-Ω 2-Channel SPDT Analog Switch 2-Channel 2:1 Multiplexer and Demultiplexer datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 12 окт 2016
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Additional FeaturesBreak-before-make
Low Harmonic Distortion
Low Power
Approx. Price (US$)0.35 | 1ku
Bandwidth(MHz)50
Bandwidth(Max)(MHz)50
Charge Injection(Max)(pC)8.75
Configuration1:2 SPDT
Crosstalk(dB)-72
Digital input leakage(Max)(uA)0.15
ESD Charged Device Model(kV)1
ESD HBM(kV)2
ICC(Max)(uA)1.2
Input/Ouput Voltage(Max)(V)3.6
Input/Output Continuous Current(Max)(mA)300
Input/Output OFF-state Capacitance(Typ)(pF)50
Input/Output ON-state Capacitance(Typ)(pF)140
Mux Configuration1:2
Number of Channels(#)2
OFF-state leakage current(Max)(ВµA)0.25
ON-state leakage current(Max)(ВµA)0.4
Off Isolation(Typ)(dB)-73
Operating Temperature Range(C)-40 to 85
Package GroupVSSOP
Package Size: mm2:W x L (PKG)10VSSOP: 15 mm2: 4.9 x 3(VSSOP)
RON Flatness(Max)(Ohms)0.2
Ron Channel Match(Max)(Ω)0.15
Ron(Max)(Ohms)1.4
Ron(Typ)(Ohms)0.45
THD(Typ)(%)0.005
THD(Typ)(dB)-86.02
Turn off Time (Disable)(ns)40
Turn on Time (Enable)(Max)(ns)50
VCC(Max)(V)3.6
VCC(Min)(V)1.65
VIH(Min)(V)1
VIL(Max)(V)0.5
RoHSНе совместим
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3A24157 (4)
  • Semiconductors > Switches and Multiplexers > Signal Switches > Analog Switch
На английском языке: Datasheet Texas Instruments TS3A24157DGSRG4
