Datasheet Texas Instruments LM95235DIMM/NOPB — Даташит
| Серия | LM95235 |
| Модель | LM95235DIMM/NOPB |
В±2В°C Remote and Local Temperature Sensor with TruTherm Technology and SMBus Interface 8-VSSOP -40 to 90
LM95235/235Q Precision Remote Diode Temp Sensor w/SMBus Intrface & TruTherm datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 22 мар 2013
19 предложений от 13 поставщиков SENSOR DIGITAL -40C-90C 8VSSOP. Temperature Sensor Digital, Local/Remote -40°C ~ 90°C 10 b (Local), 12 b (Remote) 8-VSSOP. Temperature Sensors -...  | |||
| LM95235DIMM/NOPB Texas Instruments  | 322 ₽ | ||
| LM95235DIMM/NOPB Texas Instruments  | 323 ₽ | ||
| LM95235DIMM/NOPB National Semiconductor  | 443 ₽ | ||
| LM95235DIMM/NOPB National Semiconductor  | 487 ₽ | ||
| Pin | 8 |
| Package Type | DGK |
| Industry STD Term | VSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 1000 |
| Carrier | SMALL T&R |
| Маркировка | T36D |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | .97 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.07 |
| Mechanical Data | Скачать |
| Interface | I2C,SMBus |
| Local Sensor Accuracy(Max) | 2 +/- C |
| Рабочий диапазон температур | от -40 до 90,0 до 90 C |
| Package Group | VSSOP |
| Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
| Rating | Catalog |
| Remote Channel | 1 |
| Remote Diode Temp Range for Listed Accuracy | 60 to 100 C |
| Remote Sensor Accuracy(Max) | 0.75 +/- C |
| Remote Sensor Correction | Beta Compensation,TruTherm |
| Remote Temp Resolution(Max) | 13 bits |
| Special Features | One shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection,Shutdown,Thermal diode input stage filtering |
| Supply Current(Typ) | 350 uA |
| Supply Voltage(Max) | 5.5 В |
| Supply Voltage(Min) | 3 В |
| Temp Resolution(Max) | 11 bits |
- Evaluation Modules & Boards: LM95235EVAL
Precision Remote Diode Temperature Sensor with SMBus Interface and TruThermTM Technology
Статус продукта: NRND (Не рекомендуется для новых разработок)
- TruTherm Technology PresentationPDF, 170 Кб, Файл опубликован: 23 май 2006
Серия: LM95235 (6)
- LM95235CIMM/NOPB LM95235CIMMX/NOPB LM95235DIMM/NOPB LM95235DIMMX/NOPB LM95235EIMM/NOPB LM95235EIMMX/NOPB
- Semiconductors > Sensing Products > Temperature Sensors > Remote / Multi-channel Temperature Sensors
