Datasheet Texas Instruments LM311H/NOPB — Даташит
СерияLM311-N
МодельLM311H/NOPB
Компаратор напряжения 8-TO-99 0–70
LM111/LM211/LM311 Voltage Comparator datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 27 мар 2013
Pin88
Package TypeLMCLMC
Industry STD TermTO-CANTO-CAN
JEDEC CodeO-MBCY-WO-MBCY-W
Package QTY500500
МаркировкаLM311HLM311H
Width (мм)9.089.08
Length (мм)9.089.08
Thickness (мм)4.44.4
Pitch (мм)2.542.54
Max Height (мм)5.725.72
Input Bias Current (+/-)(Max)(nA)250
Iq per channel(Max)(mA)7.5
Number of Channels(#)1
Тип выходаOpen Collector
Open Drain
Package GroupTO-99
Rail-to-RailNo
RatingMilitary
Special FeaturesStrobe
Vos Adj Pin
VICR(Max)(V)34
VICR(Min)(V)0.5
Vos (Offset Voltage @ 25C)(Max)(mV)7.5
Vs(Max)(V)36
Vs(Min)(V)5
tRESP Low - to - High(us)0.2
  • Circuit Techniques for Avoiding Oscillations in Comparator Applications
    PDF, 96 Кб, Файл опубликован: 2 окт 2002
  • Intro MF10 - Versatile Mono Active Filter Building Blk (Rev. C)
    PDF, 808 Кб, Версия: C, Файл опубликован: 23 апр 2013
    This application report describes a unique alternative for active filter designs available with the introductionof the MF10. This new CMOS device can be used to implement precise, high-order filtering functions withno reactive components required.
  • AN-298 Isolation Techniques for Signal Conditioning (Rev. B)
    PDF, 685 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note provides information and examples of isolation techniques for signal conditioning.
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
  • AN-263 Sine Wave Generation Techniques (Rev. C)
    PDF, 747 Кб, Версия: C, Файл опубликован: 22 апр 2013
    This application note describes the sine wave generation techniques to control frequency amplitude anddistortion levels.
  • +5 to -15 Volts DC Converter
    PDF, 133 Кб, Файл опубликован: 3 окт 2002
  • AN-288 System-Oriented DC-DC Conversion Techniques (Rev. B)
    PDF, 833 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation of system-oriented DC-DC conversion techniques.
  • Semiconductors > Space & High Reliability > Amplifier > Comparator
На английском языке: Datasheet Texas Instruments LM311H/NOPB
