Datasheet ТI CD54HCT163F3A — Даташит
| Серия | CD54HCT163 |
| Модель | CD54HCT163F3A |
Высокоскоростной 4-битный двоичный счетчик КМОП-логики с синхронным сбросом 16-CDIP от -55 до 125
CD54/74HC161, CD54/74HCT161, CD54/74HC163, CD54/74HCT163 datasheet
PDF, 469 Кб, Версия: D, Файл опубликован: 13 окт 2003
- Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HCT163 (2)
- CD54HCT163F CD54HCT163F3A
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
