Datasheet ТI ADS8405IBPFBTG4 — Даташит
СерияADS8405
МодельADS8405IBPFBTG4
Datasheet Texas Instruments ADS8405IBPFBTG4
16-разрядный АЦП с униполярным входом и частотой дискретизации мощности 1,25 MSPS 48-TQFP от -40 до 85
ADS8405: 16-Bit, 1.25-MSPS Unipolar Pseuso-Diff Input, Micropower Sampling ADC datasheet
PDF, 1.7 Мб, Файл опубликован: 17 дек 2004
  • Using ADS8411 in a Multiplexed Analog Input Application (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 15 фев 2006
    This application report is intended as a guide for using an analog multiplexer to multiplex several input signals to a single high-resolution, high-speed SAR analog-to-digital converter (ADC). The ADC and the multiplexer used were the ADS8411 and the TS5A3159/3359, respectively. This document discusses the important parameters of a multiplexer and defines a few important measurements for evaluatin
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
На английском языке: Datasheet Texas Instruments ADS8405IBPFBTG4
Политика конфиденциальности
