Datasheet Texas Instruments LMT01LPG — Даташит
СерияLMT01
МодельLMT01LPG
0.5В°C Accurate 2-pin Temperature Sensor with a Pulse Train Interface 2-TO-92 -50 to 150
LMT01 0.5В°C Accurate 2-Pin Digital Output Temperature Sensor With Pulse Count Interface datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 28 апр 2017
Pin2
Package TypeLPG
Industry STD TermTO-92
JEDEC CodeX-PBCY-T
Package QTY1000
МаркировкаLMT01
Width (мм)3.15
Length (мм)4
Thickness (мм)1.52
Max Height (мм)5.05
InterfacePulse Count
Local Sensor Accuracy(Max)0.5 +/- C
Рабочий диапазон температурот -50 до 150 C
Package GroupTO-92
Special FeaturesIndustry standard pinout
Supply Current(Max)39 uA
Supply Current(Typ)34 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2 В
Temp Resolution(Max)13 bits
  • Evaluation Modules & Boards: LMT01EVM
    LMT01 Evaluation Module
  • Temperature sensors: PCB guidelines for surface mount devices (Rev. A)
    PDF, 5.6 Мб, Версия: A, Файл опубликован: 18 янв 2019
    Power hungry electronic components such as CPUs GPUs or FPGAs as well as voltage regulators heat up during operation. Some applications require ambient air temperature measurements while others need to measure the temperature of a nearby component on the PCB. Measuring ambient air temperature with a surface mount technology (SMT) device is challenging due to the thermal influence of other compo
Серия: LMT01 (4)
  • Semiconductors > Sensing Products > Temperature Sensors > Cable & Probe Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT01LPG
