Datasheet Texas Instruments AM26LS31CDR — Даташит
СерияAM26LS31
МодельAM26LS31CDR
Четырехкратный дифференциальный линейный драйвер 16-SOIC от 0 до 70
AM26LS31x Quadruple Differential Line Driver datasheet
PDF, 1.3 Мб, Версия: K, Файл опубликован: 28 июл 2016
Pin16
Package TypeD
Package QTY2500
МаркировкаAM26LS31C
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
ICC(Max)80 мА
Signaling Rate10 Mbps
Supply Voltage(s)5 В
  • Wave Solder Exposure of SMT Packages
    PDF, 206 Кб, Файл опубликован: 9 сен 2008
    It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
На английском языке: Datasheet Texas Instruments AM26LS31CDR
