Datasheet Texas Instruments LM5088MH-2/NOPB — Даташит
СерияLM5088
МодельLM5088MH-2/NOPB
Несинхронный понижающий контроллер, широкий диапазон напряжения 4,5–75 В, режим тока, 16-HTSSOP от -40 до 125
LM5088, LM5088-Q1 Wide Input Range Non-Synchronous Buck Controller datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 8 авг 2014
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9292
CarrierTUBETUBE
МаркировкаLM5088MH-2
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCurrent Mode
Duty Cycle(Max)100 %
Iout(Max)10 A
Iq(Typ)3.8 мА
Number of Phases1
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Enable,Frequency Synchronization,Spread Spectrum
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)50 kHz
ТипController
Vin(Max)75 В
Vin(Min)4.5 В
Vout(Max)70 В
Vout(Min)1.205 В
  • Evaluation Modules & Boards: LM5088MH-2EVAL
    LM5088-2 - Wide Input Range Non-Synchronous Buck Controller with Hiccup Mode Restart
  • Evaluation Modules & Boards: LM5088MH-1EVAL
    LM5088-1 - Wide Input Range Non-Synchronous Buck Controller with Dithering Evaluation Module
  • Automated Frequency Response Analyzer
    PDF, 939 Кб, Файл опубликован: 9 окт 2013
    This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments.
  • Improve Power Converter Reliability Using Hiccup-Mode Current Limiting
    PDF, 480 Кб, Файл опубликован: 11 май 2009
  • Load Dump and Cranking Protection for Automotive Backlight LED Power Supply (Rev. A)
    PDF, 195 Кб, Версия: A, Файл опубликован: 16 мар 2015
    Automotive electronic systems can be subjected to wide input voltage variations resulting from cold cranking and load dump conditions. The need for over voltage protection is particularly common in automotive 12 V and 24 V systems where peak load dump transients can be as high as 60 V. Cranking condition sags the battery voltage to a low value when the battery is supplying current to an electric s
  • Reduce buck-converter EMI and voltage stress by minimizing inductive parasitics
    PDF, 926 Кб, Файл опубликован: 21 июл 2016
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
LM5088MH2/NOPB, LM5088MH 2/NOPB
На английском языке: Datasheet Texas Instruments LM5088MH-2/NOPB
