Datasheet Texas Instruments TMP275AID — Даташит
СерияTMP275
МодельTMP275AID
В±0.5В°C Temperature Sensor with I2C/SMBus Interface in Industry Std LM75 Form Factor & Pinout 8-SOIC -40 to 125
TMP275 В±0.5В°C Temperature Sensor With I2C and SMBus Interface in Industry Standard LM75 Form Factor and Pinout datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 20 ноя 2015
51 предложений от 20 поставщиков
SENSOR DIGITAL -40C-125C 8SOIC. Temperature Sensor Digital, Local -40°C ~ 125°C 11 b 8-SOIC. Temperature Sensors - Analog and Digital Output...
Элитан
TMP275AID
170 ₽
TMP275AID
227 ₽
Эиком
TMP275AID
от 468 ₽
Контест
TMP275AID
504 ₽
Package TypeD
Package QTY75
МаркировкаTMP275
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Addresses8
InterfaceI2C, SMBus, 2-Wire
Iq(Typ)50 uA
Local Sensor Accuracy(Max)0.5 +/- C
Special FeaturesConfigurable Resolution,Programmable Alert,Fault Queue,One-Shot Conversion,Shutdown
Supply Current(Max)85 uA
Supply Current(Typ)50 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2.7 В
Temp Resolution(Max)12 bits
  • Thermocouple Temperature Measurements Using Isolated Amplifiers (Rev. A)
    PDF, 145 Кб, Версия: A, Файл опубликован: 11 авг 2017
    The most common thermocouple in use today is the Type K. A Type-K thermocouple is inexpensive accurate and works reliably in harsh environments. Type-K thermocouples can measure temperatures ranging from –200°C to +1250°C and have a Seebeck coefficient of S = 41 μV/K at room temperature.
  • Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)
    PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
    This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor.
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
На английском языке: Datasheet Texas Instruments TMP275AID
