Datasheet Texas Instruments SN74LVCH244APWRE4 — Даташит
| Серия | SN74LVCH244A |
| Модель | SN74LVCH244APWRE4 |
Восьмеричный буфер/драйвер с выходами с 3 состояниями 20-TSSOP от -40 до 85
SN54LVCH244A, SN74LVCH244A datasheet
PDF, 1.6 Мб, Версия: O, Файл опубликован: 5 фев 2007
|  Купить SN74LVCH244APWRE4 на РадиоЛоцман.Цены — от 9.85 до 18 ₽ 11 предложений от 11 поставщиков IC BUF NON-INVERT 3.6V 20TSSOP. Buffer, Non-Inverting 2 Element 4 Bit per Element 3-State Output 20-TSSOP. Logic - Buffers, Drivers, Receivers,... | |||
| SN74LVCH244APWRE4 Texas Instruments | 9.85 ₽ | ||
| SN74LVCH244APWRE4 Texas Instruments | 18 ₽ | ||
| SN74LVCH244APWRE4 Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | LCH244A |
| Width (мм) | 4.4 |
| Length (мм) | 6.5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.01 мА |
| Output Drive (IOL/IOH)(Max) | -24/24 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVC |
| VCC(Max) | 3.6 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
| tpd @ Nom Voltage(Max) | 6.9,5.9 нс |
- Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
 When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVCH244A (19)
- SN74LVCH244ADBLE SN74LVCH244ADBQR SN74LVCH244ADBQRE4 SN74LVCH244ADBR SN74LVCH244ADGVR SN74LVCH244ADW SN74LVCH244ADWG4 SN74LVCH244ADWR SN74LVCH244ANSR SN74LVCH244ANSRG4 SN74LVCH244APW SN74LVCH244APWLE SN74LVCH244APWR SN74LVCH244APWRE4 SN74LVCH244APWRG4 SN74LVCH244APWT SN74LVCH244APWTE4 SN74LVCH244ARGYR SN74LVCH244ARGYRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
