Datasheet Texas Instruments LMH6647MFX/NOPB — Даташит
| Серия | LMH6647 |
| Модель | LMH6647MFX/NOPB |
2.7V, 650ВµA, 55MHz, Rail-to-Rail Input and Output Amplifiers with Shutdown Option 6-SOT-23 -40 to 85
LMH664x 2.7 V, 650 uA, 55 MHz, Rail-to-Rail I/O Amplifiers w/Shutdown Option datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 25 ноя 2014
Купить LMH6647MFX/NOPB на РадиоЛоцман.Цены — от 18 до 193 ₽27 предложений от 14 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
| LMH6647MFX/NOPB Texas Instruments | от 18 ₽ | ||
| LMH6647MFX/NOPB Texas Instruments | 26 ₽ | ||
| LMH6647MFX/NOPB Texas Instruments | 40 ₽ | ||
| LMH6647MFX/NOPB Texas Instruments | по запросу | ||
| Pin | 6 |
| Package Type | DBV |
| Industry STD Term | SOT-23 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | A69A |
| Width (мм) | 1.6 |
| Length (мм) | 2.9 |
| Thickness (мм) | 1.2 |
| Pitch (мм) | .95 |
| Max Height (мм) | 1.45 |
| Mechanical Data | Скачать |
| 2nd Harmonic | 62 dBc |
| 3rd Harmonic | 72 dBc |
| @ MHz | 1 |
| Acl, min spec gain | 1 V/V |
| Additional Features | Shutdown |
| Архитектура | Bipolar,Voltage FB |
| BW @ Acl | 55 МГц |
| CMRR(Min) | 60 дБ |
| CMRR(Typ) | 84 дБ |
| GBW(Typ) | 55 МГц |
| Input Bias Current(Max) | 2000000 pA |
| Iq per channel(Max) | 1.6 мА |
| Iq per channel(Typ) | 0.725 мА |
| Количество каналов | 1 |
| Offset Drift(Typ) | 5 uV/C |
| Output Current(Typ) | 20 мА |
| Package Group | SOT-23 |
| Package Size: mm2:W x L | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
| Rail-to-Rail | In,Out |
| Rating | Catalog |
| Slew Rate(Typ) | 22 V/us |
| Total Supply Voltage(Max) | 12 +5V=5, +/-5V=10 |
| Total Supply Voltage(Min) | 2.5 +5V=5, +/-5V=10 |
| Vn at 1kHz(Typ) | 17 нВ/rtГц |
| Vn at Flatband(Typ) | 17 нВ/rtГц |
| Vos (Offset Voltage @ 25C)(Max) | 3 мВ |
- Evaluation Modules & Boards: LMH730216
Evaluation Board for High-Speed Single Op Amp in the 5- 6-Pin SOT-23 Package
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: LMH730227
Evaluation Board for High-Speed Single Op Amp in the 8-Pin SOIC Package
- AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
Серия: LMH6647 (5)
- LMH6647MA/NOPB LMH6647MAX/NOPB LMH6647MF LMH6647MF/NOPB LMH6647MFX/NOPB
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
