Datasheet Texas Instruments LMS1585ACT-1.5/NOPB — Даташит
СерияLMS1585A
МодельLMS1585ACT-1.5/NOPB
Линейные регуляторы с фиксированным/регулируемым выходом 5 А/LDO 3-TO-220 от 0 до 125
LMS1585A/LMS1587 5A and 3A Low Dropout Fast Response Regulators datasheet
PDF, 1.7 Мб, Версия: G, Файл опубликован: 18 июл 2013
Pin33
Package TypeNDENDE
Industry STD TermTO-220TO-220
JEDEC CodeR-MSFM-PR-MSFM-P
Package QTY4545
CarrierTUBETUBE
Маркировка1.5LMS1585ACT
Width (мм)10.1610.16
Length (мм)14.98614.986
Thickness (мм)4.5724.572
Pitch (мм)2.542.54
Max Height (мм)4.74.7
Точность3 %
Fixed Output Options1.5,3.3 В
Iout(Max)5 A
Iq(Typ)7 мА
Noise38 uVrms
Рабочий диапазон температурот -40 до 125,0 до 125 C
Package GroupTO-220
Package Size: mm2:W x LSee datasheet (TO-220) PKG
Regulated Outputs1
Special FeaturesN/A
Vdo(Typ)1200 мВ
Vin(Max)13 В
Vin(Min)2.5 В
Vout(Max)5.75 В
Vout(Min)1.25 В
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
    When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet.
  • Linear power for automated industrial systems
    PDF, 1.8 Мб, Файл опубликован: 9 янв 2015
    Designing a robust power management system for industrial automated equipment requires thorough understanding of the surroundings and conditions that affect the functionality. During the past few decades industrial and factory automation systems have become more robust intelligent and connected which has drastically increased the footprint for semiconductor components. This change has created a
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • AN-1482 LDO Regulator Stability Using Ceramic Output Capacitors (Rev. A)
    PDF, 169 Кб, Версия: A, Файл опубликован: 25 апр 2013
    Ultra-low ESR capacitors such as ceramics are highly desirable because they can support fast-changingload transients and also bypass very high frequency noise coming from switching converter powersources which a linear regulator can not reject. However using ultra-low ESR capacitors on the output ofan LDO regulator requires that specific design changes be implemented to ensure loop stabili
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
LMS1585ACT1.5/NOPB, LMS1585ACT 1.5/NOPB
На английском языке: Datasheet Texas Instruments LMS1585ACT-1.5/NOPB
