Datasheet Texas Instruments UC1875J — Даташит
СерияUC1875
МодельUC1875J
Резонансный регулятор фазового сдвига 20-CDIP от -55 до 125
Phase Shift Resonant Controller datasheet
PDF, 5.7 Мб, Версия: C, Файл опубликован: 24 май 2007
Pin20
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаUC1875J
Width (мм)6.92
Length (мм)24.2
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodCurrent,Feedforward,Voltage
Duty Cycle(Max)100 %
Frequency(Max)1000 kHz
Package GroupCDIP
RatingMilitary
Special FeaturesError Amplifier,Soft Start,Soft Switching,Synchronization Pin
TopologyFull-Bridge
UVLO Thresholds On/Off10/7 В
Vin(Max)20 В
Vin(Min)9.25 В
RoHSSee ti.com
  • Phase Shifted Full Bridge, Zero Voltage Transition Design Considerations (Rev. A)
    PDF, 393 Кб, Версия: A, Файл опубликован: 22 янв 2011
    This Application Note will highlight the design considerations incurred in a high frequency power supply using the Phase Shifted Resonant PWM control technique. An overview of this switching technique including comparisons to existing fixed frequency non-resonant and variable frequency Zero Voltage Switching is included. Numerous design equations and associated voltage, current and timing waveform
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
На английском языке: Datasheet Texas Instruments UC1875J
