Datasheet Texas Instruments SN74LVC07AMPWREP — Даташит
СерияSN74LVC07A-EP
МодельSN74LVC07AMPWREP
Усовершенствованный шестнадцатеричный буфер/драйвер продукта с выходами с открытым стоком 14-TSSOP от -55 до 125
Hex Buffer/Driver With Open-Drain Outputs datasheet
PDF, 516 Кб, Версия: D, Файл опубликован: 3 июл 2008
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаC07AMEP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Bits10
Тип входаTTL/CMOS
Рабочий диапазон температурот -40 до 85,-55 до 125 C
Тип выходаLVTTL
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3,5 В
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
На английском языке: Datasheet Texas Instruments SN74LVC07AMPWREP
Публикации по теме
